Wat is dit nu weer?
Re: Wat is dit nu weer?
Paul natuurlijk
en de volgende graag! en paul, wat kun jij goed russisch typen zeg!
Deze dan maar?
iets Amerikaans ja....
Nee, niks caddie of Cadillac... wel een merk wat nu niet meer bestaat
(over enkele jaren kunnen we dat van een hele hoop merken zeggen...)
us army hoover car?
Nee, nix van danRik schreef:packard? studebaker?
Warm.... doch het "ding" heeft een merk...schoapke schreef:us army hoover car?
CURTISS-WRIGHT AIR CAR “GEMâ€
The Army Transportation Research Command purchased two Curtiss-Wright Model 2500 Air Car ground effects machines in early 1960. The purchases were for engineering and operational evaluation as part of an ongoing investigation into vehicles for use in the military.
Curtiss-Wright had developed the Air Car as a four-passenger commercial vehicle and hoped that it would be accepted by the public as a sort of air-cushioned equivalent of the family car.
Air Car model 2500
In order to increase the Air Car's resemblance to an automobile, Curtiss-Wright designers gave the Model 2500 car-like features - dual headlights, tail lights, turn indicators, rudimentary bumpers, and a convertible top.
The overall visual effect was rather peculiar, but despite the eccentric appearance, the Air Car was essentially straightforward in construction.
The Air Car was built of welded steel tubing covered by molded sheet metal. It was powered by two 180hp Lycoming engines mounted one forward and one aft of the passenger compartment.
Each engine was used to drive, via reduction gears, a single four-bladed lift fan placed within a plenum chamber. The two chambers created a cushion of air 10-15 inches thick. Forward propulsion was supplied by air bled off the chambers and expelled at low velocity through two sets of louvers on each side of the vehicle.
Air car going from water to shore
It was fairly maneuverable and could reach speeds up to 38 mph. It was not really capable of all-terrain operation and never caught on commercially.
After several months of testing, the Army decided not to fund the project further, and it was abandoned in 1961.
Model 2500 “GEMâ€
air car hovering above water
Air Car model 2500
Model 2500 “GEMâ€
klinkt overtuigend, of heb je zoveel uit je duim gezogen?
Rik schreef:klinkt overtuigend, of heb je zoveel uit je duim gezogen?
hahaha, ja, je zou het onderhand wel denken he.... maar het is helemaal goed!
